I am currently running an Edelbrock RPM Air Gap intake on my Beaumont. The intake is about 1/4 to 1/2 inch too high so the air cleaner lid hits the hood. I need an intake with close to the same performance that will fit under the hood. The engine is a .060 over 427, 10.7 compression, Crane hydraulic cam with 533 lift and 282 duration, 840 cast square port heads, 850 Holley and a TH400 transmission with 3000 stall converter.
Thanks, James
Thanks, James
