my speedo cable has broken off in the speedo housing. has anyone removed the instrument panel from a 66? hopefully there's an easy way, but i don't see it? thanks, walt
hairy
66ss396 marina blue A.C.E.S #124
walt's 66 SS.COM
Did the cable brake off inside the housing, so if you unhook it some is still left inside the housing? There are 8 bolts that hold it together. 4 on top and 4 on bottom. Problem is the upper mounts are hard to reach. They are 1/4" head bolts. I just took two dashes apart and much easier with the entire dash out. Good luck.
1966 SS Chevelle LS-7
1971 RS Camaro 402
the end that broke off is plastic. i find it hard to believe they would use a plastic end on the cable. anyway it looks like it's going to be a major task. thanks, walt
hairy
walt's 66 SS.COM
