I would like to know if there is a way to gain more access behind the instrument panel without removing it or disconecting all the wiring? Some of the things i would like to do are #1 Remove the dash pad for recovering. #2 replace or install new speakers. #3 Repair AC and heat ducts. this is impossible to do through a 1" crack. They only possible way i see to do it is to remove the steering column and this would allow the panel to drop enough to do what i need.
So i guess my question would be is it a big headache to remove the steering column at the half way down point just below the instrument panel? Thanks in advance...
