1 - 2 of 2 Posts
I recently removed my map light from the rear view mirror, and when it came out it fell apart before i could see it, so I'm not sure how it goes back together. I looked online for pictures of the assembly but I can't find any. The issue I'm having is the bigger copper piece that I'm assuming goes on the switch somehow, fell off. I'm also assuming this holds the bulb in place and makes a connection when the switch is slid over. Any help on how to attach the bigger copper piece would be appreciated. Here's a pic of what I'm working with
I have the same mirror and the same issue.
The wiring being in place makes it adaptable, but if the old design is prone to falling apart- what good is the entire assembly?
I'm looking for a way to modernize it with maybe an LED and better switch, even if it means losing the lens.
BTW, mine needs a new mirror and I'm having trouble figuring out how to remove and replace with a new mirror.
1 - 2 of 2 Posts
