I just took off a 1977 63 amp alternator off of my 68 chevelle 396. The pigtail has one clip with two prongs. The prongs off this 1977 alternator stick out of the top side of alternator. On 77 alt, the two prongs are identified as 1 and 2. From #1, a wire from pigtail #1 runs to "Bat" label screw on back of Alternator. Another wire runs out of entire wire (unmarked) and also goes to "bat" label screw on back of alternator. Then all wires are taped and go to driver side of car. (I assume one goes to battery, one to ground, and other two go to F and 2 on Regulator. I have not untapped large "main" wire from alt to driver side.
Now my problem is, I am installing correct dated alternator 1968 42 amp and on back of this correct alternator, pigtail prongs are different, smaller, placed directly on back of allternator with 2 prongs labeled F and R. Also "Bat" post on back as well as "Grnd" post on back. So I purchased "correct" pigtail from auto zone for $1.95, it appears to fit smaller opening, has 2 wires to it, but I have tried to plug into alternator does not fit. (I am thinking to sand down plastic boot to this pigtail a bit, it should slide on). Ok.... What should I do to complete this? Can I connect somehow without untapping entire large bundled wire leading to driver side and then splitting off to regulator and to interior of car? Thanks, Dave
