I have a new dual electric fan assembly with 2 265 watt motors. Where can I find 2 good relays for these?
Discussion Starter #3
Thanks for the reply. Do these relays come with the plug in harness? If not, how do I identify the correct one?
That relay is a PCB mounted relay. I think you want the 96F8266 it is a "quick connect" with a mounting tab attached to the dust cover. Or the90F8266 no mounting tab.
Related items you may want. Relay socket and wire terminals.
Note: the current carrying terminals, 30 & 87 on the 70 amp relay are larger than the standard terminals. See pic
