howdy, I own a 68 El Camino,slightly built SB 350, M20 Muncie, 390 12 bolt possi rear.Tires are BFG 235/r15 front,275r15 rear,anyways at apx 66+ MPH I start gettin a pretty good vibration goin,,not so much the car, but the hurst shifter is starting to rattle a bit, and gets worse as I approch 70 mph,apx 3,100 rpm. If I take it up to say 80 or 85+ it seems to settle down and get quiet,(smooth) again. I was thinkin of going to a higher gear ratio on the rear, say 3:55 or 3:31 to try to lower the RPM, but Im really starting to wonder if that IS the cure? Or does anyone have some suggestions on how I CAN try to get rid of the (BAD VIBES)???........Thanks Tintop55
