I'm have trouble with my 65' elcamino's
ignition or wiring. With the car at
a idle if I turn on the headlights,
heater motor, turn signal or hit
the brakes the motor dies, it seams
to be o.k. at higher RPM's.
I put in a 135 amp alt. but no help.
I'm thinking maybe a bad ground or a
bad ignition switch.
One more peice to the puzzle is, when
first get the car I found a wire and
switch under the dash running to the
starter, at first no one has an idea
what it was for, now I'm thinking it
was to seperate the ignition from the
accessories, but the wire was disconnected
and the ignition wire was spliced.
thank for the help bob
