So I shot some before and after video of my HEI ignition timing during a dyno pull. Surprisingly it jumps around a lot, and also reversed itself at higher rpms. It improves after installing an MSD weight kit, but still not perfect. Dustributor endplay is around .018. Roller cam endplay is around. 010. GM HEI with DUI rev limiting module and external coil.
Edit: used distributor, taken apart and cleaned, shaft bushings "looked" ok
Before:
After:
Sent from my SM-G973U using Tapatalk
Before:
After:
