I am assuming that your ignition switch has a tiny pin hole to the side of the key slot. Right?
If so, get a regular size paper clip, unfold it a turn or two. Insert the ignition key in the keyhole. Turn it ALL THE WAY to the accessory position. Insert the paper clip into the pin hole and PUSH it in against a spring (you will feel it) while at the same time turn the key some more past the accessory position. Now, pull the switch out of the hole. Finish unscrewing the bezel.
Tom Parsons
