Trying to determine the workthrough for this -
- turn the key lights - go on - will not start
- hold the key, after a delay it may start , iturn off and then on it may click and then may start
- by contininuing to turn the key off and then to start, eventually it will start
Tested starting at solenoid - that is Ok
Replaced one fusable link - wiring seems OK
My neighbor says, be sure to ground the fuse box (which is currently just hanging in the air under the dash)
Could that be the problem? Other Ideas?
Thanks,
Thanks,
