1 - 2 of 2 Posts
I just completed a 4 speed conversion , and now when i try to start car it turns over like the battery is dead. I had the battery load tested and charged twice, the altenator bench tested, the regulator(external), replaced, and now a new starter and seleniod. The cables are clean and tight. Nothing seems to solve the problem. After a charge it will start a few times but then turn over real slow with little power. The lites seem dim too. Is it possible the battery needs replacing even though it load tested ok?
Anything is possible but it sounds as if you have a drain of some sort. What is the time duration between the time the battery is charged and it goes dead? Have you checked for current draw with everything turned off and the doors closed?
1 - 2 of 2 Posts
