I just coverted from a sweep style dash to SS style dash with idiot lights and notice that when the ignition is in the "on" position that none of the idiot lights go on. I had the engine and dash harnesses rebuilt and all the grounds are in place where applicable.
I am also experiencing a "gen" light while running albeit a dim one. Everything was working as it should 2 weeks ago. I let the car sit for a few days and then when I tried to start the car again, I noticed these two issues.
I am a little confused as to where to start since there is more then 1 issue here. Thanks in advance for the help.
Discussion Starter #4
Elree Colby helped me find the problem Sunday morning. Seems that a faulty connection at fuse block (fuse clip was rusty) and a connection issue at the printed circuit card was to blame. After both issues were corrected, the idiot lights work as intended plus the generator light is no longer glowing dimly. Thanks again Elree for the help.
