The oil pressure, water temp, and alternator "idiot" lights on my '70 aren't working. The fuse is good and there is power at the fuse and I replaced the bulbs. I have bought a gauge set to install but I still like to have the original stuff working, kind of a "thing" with me. If anybody has any suggestions, I would sure appreciate it!
See if you have voltage on the pink wire that goes to all of those lamps. It may be easier to measure the pink wire on the fuel gage. It's the same wire. Use a test lamp and go from the pink wire to a good metal ground. See if the lamp comes on when the key is in the ON position.
