Ideas on how to mate a fuel pressure regulator to an existing carb feed line
Trying to mate this regulator:http://store.summitracing.com/partd...300725+4294846645+4294891655+115&autoview=sku
To this fuel line:http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY-34-150&N=700+0&autoview=sku
Which means I'll need a 3/8 NPT to 5/8-18 adapter. Trouble is I can't find one and I've seen the two of these together.
Anyone have this set up? Which fittings did you use? or how did you make it work?
Thanx.
Re: Ideas on how to mate a fuel pressure regulator to an existing carb feed line
Junkyard,where do you plan to mount the regulator? Fenderwell?
Have you already bought the carb feed line you posted a link to? If not check the one in the link below. It has a guage and filter and 3/8 NPT inlet.Only $10. more ,but you'll save that on fittings alone.Then you can run 3/8 NPT from your pump to the reg. and 3/8 NPT from the reg. to the carb feed. I've run this with no problems for years.Check the engine pics in my showroom and you'll see the setup.The only difference is I run a braided line from the reg. to the carb inlet line. Hope this helps.Easier than finding aeromotive fitting AER-FBM2108,AER-FBM2915 and AER-FBM2005 (5/8-18 to 6an to 6an to 3/8 NPT).
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM-G3120&N=700+115&autoview=sku
Ken
Yes I already have the dual feed line. And I also already have one with a hose barb.
I was planning on connecting the regulator directly to the feed line.
Pipe nipple? there both 3/8 the inverted flare is 5/8-18 and connects to the fuel bowls correct? Ok read it again, buy the 3/8 inlet line or AN fittings with a coupling. Is the inlet flare?
