This is on my 69, i have a clip that im not sure where it goes. It comes out of the harness around the radio area. It has one yellow wire and one black wire (about 18gauge i think). They both go into a clip with side by side vertical female connectors.
There is one more. It is an orange wire that hangs down below the glovebox. It have a long gray plastic connector thing on the end of it. I need this one ID'd also. I cant find it in my wiring book
THanks. The glovebox wire is missing part of the switch i think. It has no 'guts'. Its jsut hollow.
I ak getting power from the yellow wire terminal. Is this supposed to have power being that it only plugs into speaker harness?
"Is this supposed to have power being that it only plugs into speaker harness?"
Yes the yellow is power from the fuse and black is ground. The power and ground just pass straight through the speaker harness connector to the radio.
