Hello folks,
I have several questions about replacing the convertible top hydraulics. In particular, about refilling the system. I've seen several different methods described - including, I think, one here in the tech forum (which I can't find again). That one described running a line from a quart of atf directly into the pump and running the top up and down a few times. One question about that: can the motor remain in place when doing that?
I've also seen a method which specified that the motor had to be higher than the pistons when filling it with fluid. If the answer to the first question is yes, it seems like the line method would be easier. Any opinions or thoughts on these different methods?
The fluid in the lines now is pink, so I'm assuming it's atf. Is there any way to be sure of that? The reason I ask is that the pump still seems to be operating fine, so I'm only replacing the lines and pistons now (the old ones are leaking) - so there will presumably still be some old fluid in the system. Or should I ensure that the pump is drained too? Did they ever use brake fluid in a '66?
Finally - what's the best way to minimize a mess when taking the old system apart? Is there a good way of draining it before disconnecting the hoses?
Thanks for any help.
