I have been looking at solid rollers a bit and have been noticing the huge lifts they accomplish. I have a 350 with Iron Eagle Plat 200cc heads and 177 blower running 7psi. My cam is a hyd flat 218/230 and .462/.480 113 ls, the combo works really well.
My question is if I went to a solid roller that performed in the same rpm range, but had something like .550 lift, what kind of performance increase would I see possibly? Other than valve springs and valve clearance, what else needs to be considered when swapping? I have ZERO experience with roller cams. Thanks for any input!
