could someone give me a ballpark figure of HP and Torque.
-350 (block from chevy 94 1500)
-9.5:1 compression
-headers
-dynomax exhaust
-edlebrock RPM intake
-don't know what kind of heads (supposed be descent) they have had valve job done ($400 worth of work)
-Comp Cam (basically the 268H)
468 lift
218 duration
110 lobe seperation
Not sure what else is need for cam specs
-1.6 rockers (not sure if roller)
- 750 holley carb
Any guess/prediction would be great
Tom
BTW i know that the knwoing the kind of heads will make a big difference, but input would be appreciated.
My guess is 365HP/350TQ at the crank, assuming moderate head work.
The real power is what ends up at the rear wheels (depending on type of trans).
It has a 700r4 so it will be using up some horsepower before it hits the rear wheels. i also have a 2.73 rear and stock converter. ( I know it doesn't have anything to do with HP) So that is going to slow me down until i have the money to replace that stuff.
What kind of power do you think it would make at the crank and rear wheels with little to no head work. (i would rather underate my engine)
Tom
