1 - 11 of 11 Posts
UPDATE: THESE HAVE BEEN SOLD THANK YOU FOR ALL THE REPLIES
I have a question about stock Valve cover applications
So I am selling these 454 Valve covers and need to know if you have mill down the tabs in the pics to use on Gen IV heads ?? Some say yes other say No just use the right Oring gasket and wont have an Issue I need to know 100% if you have to mill tabs off to use on the 781 heads or any other Mark IV and lower head
Grille Automotive lighting Motor vehicle Hood Bumper
Grille Hood Automotive lighting Motor vehicle Automotive exterior
Hood Automotive lighting Automotive exterior Vehicle door Electrical wiring
Automotive lighting Bumper Automotive exterior Vehicle door Hood
How’s it going!!! I figured it had to be somebody from the g3 forum. The covers looked familiar but the 74 user name threw me off. Sneaky!!
I cut those tabs off on my valve covers like that and they sealed to the heads very well with 0 leaks.
The tabs are to prevent you from over compressing (crushing) the valve cover gasket these covers use.
if you look at the sealing surface on the older heads like 781 and 049 it is not as wide as the gen 6 heads. when i tried to use the oring it leaked. i milled the tabs down and used a regular gasket and worked fine after that
can you just use a angle grinder to cut the tab down? jim
1 - 11 of 11 Posts
