I just put a HEI ignition in and was wondering where I need to get the hot lead from to run it? Thanks,
Andy
I assume you are converting from points if so run a wire from your ignition terminal on your fuse block to the terminal labeled batt on your hei.The old points wire cut it back as far as you can and tape it up. dom
Many thanks, thats just what I needed to know.
Andy
