1 - 2 of 2 Posts
I have a '64 Elky... the horn does not work... How do you run a wire from the horn to a button switch below the dash? what wires do I look for on the horn or what wires are the correct ones on the steering column.
thx,
Before you install an extra switch, have you tested the horn to see if it works? Does the horn relay work? There's a small black wire, attached to the horn relay, that the horn button grounds. This activates the horn relay and blows the horn.
1 - 2 of 2 Posts
