Andy, here are six screws that go up thru the instrument panel into the pad. Four are located above your instrument cluster, and two by the glove box door. You can see them looking up from below.
Take out those six screws and carefully lift the back end of the pad while pulling it aft. There are also six clips on the front of the pad. Your pad will slide out with the clips attached.
Jim
