I need to remove the forward lamp harness and engine wiring harness at the firewall.
They both connect at the firewall with the engine harness on the left (facing firewall from front of car) and the forward lamp harness on the right.
I have removed the bolt from the connector. It appears that the engine harness is suppose to come out first followed by the lamp harness. However, neither wants to budge. Is this the correct order?
I don't want to break something and I am not sure how hard to pull. Therefore, I just wanted to see if there is anything I should watch for when removing these two connections at the firewall.
Thanks.
John M. Usher
Starkville, MS
1969 SS 396/325
TC#147 / ACES #3063
Thanks.
John M. Usher
Starkville, MS
1969 SS 396/325
TC#147 / ACES #3063
