This might be a good read and/ for a Sticky for the Wheels & Tires Forum
Every car is different from Driver Side to Passenger Side
and taking measurements of your car's Rear Wheel Wells etc
is the key to what Wheel / Tire Combo size will fit without rubbing or hitting anything ;
BACK SPACING & WHEEL WELL / Shock Mount Room https://www.rsracing.com/tech-wheel.html
First measure with the current sized Wheels/Tires on the Car ;
1.Wheel’s Rim room inside curved lip of Wheel Rim to bottom part of Shock Nut =
This is because as you increase the Back Space on a Wheel
and or increase the Width of the Wheel it may interfere with the Lower Shock Mount/Bolt
2.SPACE from Front of Fender Well to front of current tire when mounted to rear end this is for to measure the MAX height/diameter a tire can be as it is Important that you allow Bias tires a growth margin .
Second with the Wheels/Tires removed from Both DR & Pass sides, one side at a time or all same time
measure the following;
A. Rear End Width – Face of Rear Brake Drum/Disc Driverside to Face of Drum/Disc Passengerside = ??“
B.
OUT SPACE from inside Lip of outside Fender to Face of Rear Drum/Disc Brake Hub/Wheel Mounting Pad
................. DR Side = ??“ .... PASS Side = ??”
C.
IN SPACE from Face of Rear Brake Drum/Disc Hub/Wheel Mounting Pad to Frame/Inner Fender
D.
Total Wheel Well Space = # 2 + # 3 measurements #s
if one side is less then use it as the applicable number
or make sure the Rearend is centered properly
Important things to NOTE;
1. the Rear Lower Shock Mount Bolt may interfere with the Wheel’s Rim
2. and yes your car's exhaust may interfere with the Tire on a 10" Wide Wheel
3. Type of Brake system on rearend, Drum or Disc ! as the Disc setup is usually wider than a Drum setup
4. Is Rearend centred ?
5. Has the car been Lowered ?
6. Side Wall/Section Width of the Tire = ?
7. Diameter Height of Tire = ? Note to make sure a to High of a Diameter Tire is not used ;
Measure from the Centre of the Wheel towards the Front of the Car to the Body behind the Door
to see how much Space there is = ?? X 2 = for the Max Diameter Tire to use LESS a little ! EG. 14.5” x 2 = 29” Max = 28”
8. Size of Wheel you wish run ?
Measure twice and you will only need to buy once the Wheels/Tires Combo
you want to fit within your car’s Wheel Wells .
Here is an Example ;
My 67 Chevelle with a 60” Wide Rearend
Car's Wheel Well Measured
Total Wheel Well Space = 13"
This is based on the following;
B. Measuring from the Face of the Drum Brake on a 60" Wide Rearend OUTward to the Innerside of the Fenderside =
5.92" OUT Space
C. Measuring from the Face of the Drum Brake on a 60" Wide Rearend INward to the Frame =
7.08" IN Space
D. B.# + C# =
13” Total Wheel Well Space
E. Just to Double Check, Measure from the Fender Inner lip to the Frame/Inner Fender =
13"
So here is the cal for my Car's Wheel Well to see what is the Best/Biggest Wheel / Tire Combo to Fit without any Rubbing etc. ;
Out Room from Fender Lip to outside Tire Side Wall and inside Tire Side Wall to Frame
IN Room
Wheel 8“ Wide with a 4.5” Back Space
a. the portion of it towards the
OUTside / Inner Fenderlip = 3.5" = 43.75%
b. the portion of it towards the
INside/Frame = 4.5" = 56.25%
Tire Mickey Thompson ET Street S/S Radial Tire P275/60R15 = Dia 28.2"/ Tread Width 9.3"/ Side Wall Width 11.1"
Max OUTspace 5.92” 1.07” = Room To Tire Sidewall from FenderLip
4.85” outward TIRE inward 6.25” Room from Tire Sidewall to Frame =
.83” Max INspace 7.08”
Wheel 10 “ Wide with a 5.5” Back Space
OUTside / Inner Fenderlip = 4.5" = 45%
INside/Frame = 5.5" = 55%
Tire Mickey Thompson ET Street S/S Radial Tire P295/55R15 = Dia 27.8"/ Tread Width 10.6"/ Side Wall Width 12.2"
Max OUTspace 5.92” .43” = Room To Tire Sidewall from FenderLip
5.49” outward TIRE inward 6.71” Room from Tire Sidewall to Frame =
.37” Max INspace 7.08”
