I have a '70 El Camino and there is a rust hole about the size of an oblong quarter by the bottom bolt that holds on the steering box. The rest of the frame seems fine with just surface rust all over and rust flakes in some spots. Should I get a new frame or make use of what I have?? It doesn't flex at all like when I'm going around corners and stuff and there is no other holes in it.
Also, I noticed that the shock mount bolts are loose (where the shocks mount up to frame), is this dangerous? The shocks have obviously been replaced and there is only 1 bolt holding the mount in. Thanks a lot.
1970 Chevy El Camino aka Kaileigh
Green Mist #45 & Silver w/Green Vinyl Top
350ci/300HP 4bbl Small Block
Factory Dual Exhaust and Rally Wheels
My El Camino Home Page - www.dreamelectric.com
I hate rust!!!!!!
I hate rust!!!!!!
