I use to have turn signals, but last year I thought I smelled smoke, and the flasher was very hot... I unplugged the flasher unit...
Brake lights, dash lights, headlights, running lights, tail lights, backup lights all work okay... I recall all the blinkers working too...
I tried to hook them back up later, and they work, but I am worried that I will have the same problem, but worse...
I think some of the problem might be the switch at the column... its a 1966 Chevelle with a tilt column, so the switch is under the dash. It seems to work, but some times they are hard to shut off (mis adjustment and non-functioning cancelling cam). I thought of getting one of those loud audible flashers so I could here it over the exhaust and stereo, but I thought it might be too loud...
How would I go about checking the system? Should I disconnect all the turn signals and test them one-by-one?
I guess I also need one of those Multi meters (I only have a test light and a voltage guage)...
Also, how do I determine what size wire I need for a particular circuit (based on amps, correct?). Is there a chart around for different amperages and wire lengths so I can size the wires properly?
Thanks,
Tony
"Once you go RAT, you never go back..."
TC #1366
Tony
http://www.chevelles.com/showroom/Quik66.jpg
http://www.chevelles.com/showroom/eng7.jpg
Thanks,
Tony
TC #1366
Tony
