Had new CPP disc brakes with 2" drop spindles put on my 67, and am thinking about putting regular height spindles back on... sits too low. Headers and frame/pan have about 2'' ground clearance.
How hard is it to change the spindles (I obviously didn't put the dropped ones on, or else I would know how to take them off). Need some basics on how to swap out the spindles (will also need to buy some new ones - what are some good brands for original height spindles?). Is there an easier way to raise the front up?
I'm a rookie on brakes and suspension, but willing to give it a try. Any links and/or instructions would be appreciated.
Also need to replace my brake proportioning valve that is leaking. Really dumb question, but how do you prevent the master cylinder from draining out when you undo the lines to hook up to the new valve (do it really fast?)
thanks
thanks
