I have a short in the 37 year old switch. I thought it was the neutral safety switch but that wasn't the problem. I understand there is a trick to changing out the ignition switch. Any advice would be appreciated.
What trick do you need? How to remove the key cylinder? Needs to be turned CCW past ACC with the key in and a stiff rod depressing the release button. Rod goes in the front hole.
That's what I needed to know, Thanx John.
If you are changing out the complete swith it is also recommended to get the "bezel removal tool" to get the chrome bezel off. It does just screw off but it's hard to get a grip on it without the tool and you can damage the chrome using pliers etc.
