What does the top screw in a driver side heat vent(on dash) go in to???? There is nothing for the screw to fasten to.... BTW - '69 velle..
Also, how does the felt strip go back in to the vent???
This thing has me totally :confused: :confused:
TIA Scott
Scott,
Regarding the vent, I do not know. I installed the vents on my non-A/C '68 and I glued a metal strip behind it to fasten the top screw.
The felt strip is glued on. I used the Weldwood Contact Cement. You have to take apart the vent first.
Theo.
Scott
There is a metal clip that the screw threads into and then clamps the dash between the vent and the the clip. pretty easy to make, I can post a picture if you like. Theo, received your letter, glad the template worked for you.
Steve
