I've seen people shave there door handles and locks to make the car look smoother..
I've seen it on conv. cars till now.
But 2 days ago, I saw it on a HT car...
I always wanted to do that. But i thought i'll have to get a convertible, because how else will i be alse to open the door?
But when i saw it on the HT I was puzzled...
How can you open the door if there is no door handle of key lock to unlock it?
HOW???
Remote control (like and alarm thingy) or a hidden solenoid.
I'm sure there are other ways, but this is what I've seen
http://www.mrgasket.com/ftp/pdf/ElectricAcc.pdf
page down to page 6 till you find part #6188 "universal electric door release kit"..Its popular with the Rod and custom crowd.
You can sleep in your car,but you cant drive your house.
Tony. H . 406 powered , Mohave Gold , 72'Malibu
[This message has been edited by hoffbug (edited 04-26-2001).]
If you do that, just make sure you have someway to get in the car if the battery dies or if a fuse blows on the relays for the soleniods.
64 Malibu SS 327
Parting out 1965 El Camino
Instructions?...all I need is the exploded view
I did that to my 67 SS hardtop. I have both electric solenoid operated doors and electric windows. Normally I just *roll* down the window and reach inside to the mechanical door handle to open the car. I have two key fobs that actuate the windows and electric door pulls in case I happen to misplace one. I also have an emergency door button under the hood.
The only caveat is to make sure the battery is up at all times. I also removed the door lock mechanism so it won't accidentally get locked - with no door handles what good would it do to lock it and have someone get in with a coat hangar?
The electric windows are from Autoloc. Forget the exact price but you can get to them via http://www.autoloc.com . I also got express up and express down (one push of the button) for both front windows. The door solenoids are inside the door panel just like the electric window mechanism. The solenoids, key fobs, and electronics are from Dakota Digital.
The electric window mechanism requires almost no fabrication at all...it actually turns the factory regulator. For the door pulls, I simply removed the factory rod from the handle to the latch, replaced it will 1/16" steel cable and connected the door actuator to the latch itself. That way it doesn't have to pull against the inside door handle, just the latch.
Cost:
Dakota Digital Commander 9000 CMD9001 - $250 x 1
Autoloc electric window kit PW3900 - $200 x 2 kits required for front and back.
Autoloc one-touch up/down WC1000 - $35 x 2 (1 for each front window)
Extra strong door actuators SL40 - $95 x 2
Total cost: $910
Would I do it again? Given the interior work, along with the aesthetics of the rest of the car, probably, yeah.
I hadn't planned on electric doors. I wanted flush mounted, color-keyed ourside door handles - much like an import has. Fabricating an effective way to make them work would have been bunches cheaper. When you think about it, the electric door pulls only consisted of the heavy duty actuators ($190) and they make less expensive ones. The remaining $720 was in the windows, one touch up-down, and fancy controller.
Check out http://www.dalesplace.com/htm/chevelle/chevelle.htm and click The Interior button to see how it all works.
Dale McIntosh
TC Gold #92
ACES #1709
www.dalesplace.com
Restore it or customize it, but drive it and enjoy it!
