.025-.030 IS EXACTLY WHAT THE MACHINEST CUT FROM MY INTAKE AFTER HE MINIMALLY DECKED WHAT WAS MY VIRGIN 396 BLOCK & HEADS.
opps,sorry about caps.
scott
scott
=A little history on this issue.
454 LS-5 0 decked to .013 with flat top piston 290 heads which cc at 100.9 CC
Block was decked and I'm sure the heads were as well. I cannot be sure of the amounts but I am getting oil in the chambers on deceleration. I have an UNCUT Edelbrock Performer RPM on the engine. I suspect I need to cut the intake and need an educated guess as to how much. From what I can figure out the block appears to be cut between .025/.030 to get the deck height and have no idea on the heads.
Any one care to offer some advice????
=Hi Mike. Thanks for the input. I know there is a way to determine if the head decks were cut (measure the triangle shaped are on the block side of the head) but is there any way to determine if the intake faces were ever cut and if so how much?
Perplexing problem when machine shops only cut the block surface.
Also on your point about the intake being correct--- How would you know if it is right or not?
