1 - 8 of 8 Posts
I have a Powermaster 1 wire CS-130 alternator on a serpentine set up. Mark from MAD Enterprises suggested using it as a 3 wire. I took his suggestion, added the plug that sees battery voltage on the large gauge wire and added a resistor to the smaller grey wire. Since I don’t have an idiot light, the resistor was needed. With the engine off and key on run, I have 12.5v on the 10 gauge wire and 11.80v on the grey. When running, the alternator is putting out 14.7 volts. Is that too much? There is another recent thread that said, high 14v can over charge and damage your battery.
Joe
Automotive tire Motor vehicle Automotive lighting Luggage and bags Bicycle handlebar
Automotive tire Motor vehicle Tire Sports equipment Automotive design
Automotive tire Finger Electrical wiring Gas Cable
14.7 is the highest voltage needed to charge a partially discharged battery. If it doesn't drop down after driving a while I'd start looking for problems. Don't panic just yet though.
Reactions: mrjay53
I would just run it and see how it works before getting all carried away, especially if your battery is under warranty. I think most alternators charge at 14.4 Volts if I remember correctly. I have Dual 320 amp alternators in my chevelle.
I had 14.7 volts for many years measured with a Fluke 87 at the battery terminals.
It never went any higher even at 6500 RPM.
My old lead acid battery lasted 7 years.
I drove it daily.
I built another Internal regulated GM for the wife's Ford Escort and it put out the same 14.7.
No issues with that and those blinkers were much faster and lights were brighter.
1 - 8 of 8 Posts
