1 - 20 of 41 Posts
Gentlemen,
Building my 454 .030 over motor. L2349 pistons should yeild about 10:1 compression. Intake is Edelbrock RPM Air gap. Have not purchased carb yet. Rear end will be 3.73. TH400 trans with approx 3200 stall. Car is 66 Chevelle and will be 90% street and not a daily driver.
Heads are GM 049 castings that have been reworked by a reputable builder who frequents this site. Have 2.19/1.88 SS valves. Flow sheet I was provided with heads reads as follows:
28" 4.350 Bore
Good Port Bad Port
2 162 2 162
3 228 3 222
4 286 4 270
5 311 5 302
5.5 313 5.5 311
6 313 6 318
Im leaning heavy towards a hydraulic roller camshaft but have not made a decision as of yet and want to get the combo correct. My question is how much split should I be looking for in a camshaft? Hope I provided enough information for some insight. Thanks in advance for any replies/recommendations. Always appretiate the expert advice and learning tools I get on this forum.
Thanks again,
Scott
Scott. how big do you want to go?? L2349's may need to be flycut deeper if you go much larger than a 230-236 intake lobe, depending on the ICL. What mannerisms do you want? Personally, I would go 6-8* split. If you can locate one, the Crane 741 cam (236/244, .610/.632 112LSA) works well. A little more knarly- and a bunch less idle vacuum, VooDoo 60213 (241/249, .625/.625 110 LSA).
Do not loose too much sleep over it. Once you get it togeter , you wont be able to tell the differance anyway.The Exhaust side of a camshaft is not as important as the intake is, neither is the exhaust flow in the heads.
JOE SHERMAN RACING ENGINES
Joe, what about a single pattern cams...they work?
Single pattern cams work very well if you do not need an extended RPM range above the actual HP peak. In most street engines, a single pattern cam will run right with any dual pattern grind if the lobe design is a good one.The dual pattern will make a differance if the exhaust system is not as good as it could be( poor mufflers and or pipes )
You would think a dual pattern cam would be a disaster with stock-type heads, but Comp musta knew something when designing the Magnum line. Figure they never would of sold them if they didnt work good.
Harold recommended a solid roller, .725/725 251/261 on a 110lsa for my sons street/strip 80 Malibu running a 150 shot of nitrous. Its a .030 over 454 with 781's w/air gap intake. If all goes well he'll be running it Saturday night. Its gone a best of 11.5x on motor, 10.6x on nitrous,3.90 gears and my old 10" ATI converter, Harold thinks high 10's on motor now.
Ran a Jay Allen custom SR cam in my 540...over 16 degrees split duration...with AFR 335 heads. ;)
Bill, 16*...what's up with that :eek:???
I guess its not that important maybe as BigJoe says, but 16* does sound like alot. Does that cam run good?
You need the split if you have a poor intake/exhaust ratio head and/or crappy exhaust.
You need the split if you want to make power upstairs in the rpm range.
The exhaust side IS important, if you can not get out what you are putting in, that causes reversion and drop in power.
It is all about the combo and intentions of it.....
FWIW .......I run a Chris Straub solid roller with 16* split .......Brodix ovals approx 61 i-e ratio....big improvement over my old solid roller of similar duration with 8* split ..works for me :0
Old school theory :noway:
Full CNC ported 335cc AFR heads which have one of the best I/E ratios for a mass produced conventional head. Actually bounced this cam choice off Tony Mamo who had great interest in the results.
Intake is a R-M CNC Super Victor.
Exhaust system was 2 1/8" Hooker Super Comps. Over .800" gross lift...engine was shifted/trapped @6500. Gained over 27 mph on the back half of the track.
Tony may have had great interest, as it should NOT have worked for those heads.
Old School Theory? Tell that to Harold Brookshire -
This can be read HERE
"Of course single pattern cams make more torque. That's why Pro-Stocks use 20* bigger exhaust cams at .050, to kill off ALL the torque in the engine.........
There are all kind of reasons to run single-pattern cams.
There are just as many, or even more, reasons to run dual-pattern cams.
There are even reasons to run reverse-pattern cams.
It all boils down to two things, What the cylinder head flow needs, and what the customer wants the engine to do.
I have made lots of hydraulic cams that are single-pattern. I have made hydraulic cams that are smaller, and bigger, that are dual-pattern cams. Both types worked fine for what they were supposed to do. I even tried to talk Holley into 1 or 2 single-pattern VooDoo cams, but then, Comp didn't make any single-pattern Xtreme Energy cams.
At UltraDyne I had a single-pattern flat tappet finish 2nd in the Winston Amatuer Championship.
There are reasons for everything. The trick is knowing the right reason for any application.
I sold 2 reverse-pattern roller cams to a customer today. About 90% of what he buys, and he buys them 2 to 6 at a time, are reverse-pattern. He also helped me develop the 283/289F6 flat tappet, and he's bought a lot of those.
My most popular flat tappets are 6 to 8 degrees larger on the exhaust than on the intake.
The most popular rollers are mostly 8 degrees larger, some only 4, some 16 to 20.
A cam should always be made for what the customer wants the power band to be like.
All of the above are the correct answers."
You can read the below HERE
"All these facts, or theories, change with RPM. What is true at low RPM is not true at high RPM. All cams are a compromise, until we go to digitally-generated valve lift curves.
The longer you can keep an exhaust valve closed, the longer power stroke you have, and the more torque gets put into the crank. Single-pattern cams keep the exhaust valve shut longer, so more bottom-end torque.
At higher RPMs, past peak torque, the most important thing is getting the exhaust out of the cylnder so a fresh charge can get in. If you can't get the exhaust all out, you can't fill the cylinder as full, because old exhaust is still in it.
You notice this most often when you hit peak power. The Torque/Horsepower curve takes a bigger drop, caused by an inefficient exhaust system or cam.
Single-pattern cams make good bottom-end, but limit the top-end horsepower.
Dual-pattern cams make good top-end, but give up a little bottom-end torque.
Reverse-pattern unblown cams are a special case of type one and type two.
They aren't usable except in very limited carburetion applications, where the carburetor limits the maximum amount of horsepower."
Now, what say you? :D
1 - 20 of 41 Posts
