1 - 8 of 8 Posts
I am working on a 70 with a stock am-fm mono radio with fader control switch.I was wondering if it could handle 4 stock speakers?I would like to use 2 4x6 8ohms up front and 2 10 ohms in rear.The radio used to run 2 stock 6x9 speakers in the car I took it out of.Do you think that would be too many speakers for radio to handle? Thank's,Jim.
Your stock radio should have 10ohm speakers and only one front and one rear with fader. Any lower than 10ohm may damage the output transistor. A mono radio only has one speaker output. The fader allows the addition of a rear speaker and controls the load on the output so that it sees 10ohm impedance all the time.
Steve,
I plan on running four 8 Ohm speakers in my stock 72 Chevelle stereo setup. I believe my stock radio was stamped 8-10 Ohms. It's all packed up now. Do you think it's o.k?
Mike
Stereo radios have built in front/back and left/right faders which control the load. 8 ohm will probably be ok if you don't crank the volume to the max. Remember these radios are 30+ years old. There is some very good info on this site at http://www.chevelles.com/radiotech/index.html from Joe Hubka. If you have an original radio I suggest you spend some time reading all you can on these pages.
1 - 8 of 8 Posts
