There is a spring loaded button on the side of the switch itself, reach under the dash until you can get your hand on the headlight switch then feel around and you will eventually find the spring loaded pushbutton, then turn pull out on the headlight switch until you turn the lights on then push the button and the entire knob and rod will come off when you pull it.
If I Can't Drive It, I Don't Want It!
myhot69
Darryl, TC#925
Remove the spanner nut off the front of the switch. I use a pair of needle nose pliers to get into the slots on each side.
My 70SS
