1 - 12 of 12 Posts
It's pretty simple. Put down some tape around the wiper arm shaft. If you look at the bottom of the arm you will see a little stainless tab that sits in the grove just below the splines. With a small screwdriver carefully pry the tab off the shaft and pull up and off.
If I remember correctly after releasing the clip it seems to come off the shaft easier if you pull harder on the side opposite the clip.
66 Chevelle SS396 & 66 Chevelle 327 Convertible.
Thanks everyone, I have them off. Now another problem, it feels like there are some kind of clips or tabs holding the cowl cover in place. It is all loose; but it doesn’t want to pull straight out or up.I don’t want to pry too hard and chip or break something.
Thanks. When I lift up and pull forward it comes a little ways and then hangs up on something, I didn’t want to pull more as I was afraid of messing something up. I located a lose cowl and firewall, so I will take a look at those tomorrow. Thanks again
make sure to coat the wiper shafts with anti sieze before reinstalling the arms. It makes it easier, although not easy....
1 - 12 of 12 Posts
