I would like to check for leaks before starting the engine. The Chevelle has been sitting for over a year. During that time, I replaced the fuel lines between the mechanical fuel pump, regulator, filter and carburetor. These are all double flare aluminum, so I really want to sort out leaks and makes sure the flares are good. I could rig up an electric pump as a "puller", but can I pull fuel from the tank though the mechanical fuel pump?
