Jelco- Are you looking for just mufflers? Hydro462 was right, 20" Dynomax Super Turbo's #17749 will quiet your car while still sounding like a muscle car. Most chambered mufflers are on the loud side, and drone. Flowmaster makes a couple of quieter versions- Super 50 & 70 Series, and they control drone nicely. Straight through mufflers have a high tendency to drone, but Magnaflow seems to be the exception to this. And it goes without saying that the longer the the muffler, the quieter.
Drone is rpm specific- usually between 1800-2400 rpm. If your final drive ratio is around 2:56- 3:08, your cruise rpm will be in that range so once again, a turbo style muffler will help.
If you need a complete system, an X-Pipe will quiet it down. But be aware that it will also change the tone. It will sound smoother and more modern. Some like it, some don't. An X is usually good for top end HP without affecting bottom end.
An H-Pipe will quiet it down
slightly without affecting tone
, and help with bottom end without affecting top end.
There's some good info and sound clips here to help you with your decision-
Exhaust 101
