1 - 18 of 18 Posts
i’m assuming i need to take the dash pad off but what bulbs do i need and any recommendations for this project?
Yes, remove the dash pad by removing all the screws along the front edge and pulling it back towards you to release the securing tabs long the windshield side. The speedometer and SOME of the other bulbs will be fairly accessable from the top. Carefully twist and pull out the plastic bulb holders. There will be #194 bulbs in them. Replace the bulbs and test their operation before putting the dash pad back on.
Reactions: LeoP
Dan he's in school and working so I'm pretty sure $ is a little tight and new bulbs are cheap :) just be careful pulling the sockets out they break easy
wow seems pretty simple, i thought i’d have to take some other things apart, thank you!
Stick a Dakota Digital Cluster in there and it'll look like a brand new model where bright is concerned while maintaining the old appearance.
wish i had to money to have something like that but for now i’m working on a budget, thank you for the recommendation i’ll definitely check it out for the future
Yes it is a luxury add on for sure. Check your dash ground. My 66 dash lighting was fairly weak as well. I saved up the money to make the change myself. Many are on a fairly tight budget right now so you're not alone there. Good luck..
When you remove the pad there are 6 screws that hold it down. 4 are in the area above the gauges and 2 are in the front top of the glove box.
I've been thinking about putting the cheapo ebay LEDs I have in my dash, hum maybe I'll try them with the dash semi installed
I suppose I don't really need to wait for an answer --- I have both types of dashes (one in the car, one in pieces on a table).
Sweep cluster is the easier of the 2 - only 5 bulbs directly across the top of the cluster assembly. The left-most one is the power feed, so do be careful with that one.
706465
706466
The SS dash has a ton of bulbs. First the view if you'd be looking from above, and then the rear. All of those black "plugs" are the lamp holders. 15 of them!
706467
706468
1 - 18 of 18 Posts
