1 - 10 of 10 Posts
How can i find out what type of big block it is, what type of trans, and what type of ten bolt is in the car?
the car came from the factory as a base 307 chevelle. previous owner converted it to a big block with powersteering (i’m assuming 396, he said it was a 454 but his friend who sold it to me said it was a 396). the transmission is an automatic (i’m assuming a three speed [P,R,N,D,2,1]). the differential cover has ten bolts so... i’m assuming it’s a ten bolt.
(also what’s the difference between a turbo automatic trans and a power glide?)
On the passenger side in front of the cylinder head is a flat pad should have numbers and letters stamped on it, also on the back of the engine where the transmission bolts up will be casting numbers.
Powerglade is a 2 speed turbo 350 and 400
Is a 3 speed.
On the front of the axle tube there should be stamped numbers.
Go on chevellestuff.net. there are awesome examples.
Is a 3 speed.
you guys are quick! thank you!
Is a 3 speed.
Start here with identifying the engine.
thank you i’ll check on the site and get under the hood
Kyle for these easy Questions you should be Searching on Line
EG. type in GM Transmissions and you will get this
General Motors transmissions
Here is a Pic of the Automatic Transmission Pans that will help you Identify which Trany you have
707737
1 = PowerGlide 14 Bolts / 2 Speed Auto
2 = TH 200 11 Bolts
3 = TH 350 13 Bolts / 3 Speed Auto
4 = TH 400 13 Bolts / 3 Speed Auto ( the Strongest of the 3 Speeds )
5 = TH 200-4R 16 Bolts / 4 Speed Auto
6 = TH 700-R4 or 4L60 or 4L60E 16 Bolts / 4 Speed Auto
7 = 4L80E 17 Bolts / 4 Speed Auto ( the Strongest of the 4 Speeds )
This will get you info on anything about your Car
Have you started to take down Notes on this stuff we are Spoon Feeding you ???
Reactions: japete92
2 = TH 200 11 Bolts
Or, at least 'bookmark' the ones of interest. Down load and save any interesting attachments. I'm 72 and I know how to do that; I've got SOOOO MANY; organized in 'folders'.
Pete
1 - 10 of 10 Posts
