1 - 16 of 16 Posts
You might be able to try a heat gun on the manifold and twist it.
BTW who makes that tube??
I have been looking for one with the fitting for PVC so I can use my oem 327 valve covers
66 Chevelle SS396 & 66 Chevelle 327 Convertible.
Discussion Starter · #3 · (Edited)
Most corvette or Nova suppliers. Some Chevelle venders. I thought about heating up the engine to.get the intake to expand at a faster then the steel tube to make not so tight. I wonder if there is some kink of tool like the oil filter removal tool that you could slip around, tighten, and rotate Titan Tools 21315 12" Strap Wrench.
· Super Moderator
Like Humberd said . . . take a rubber mallet and smack it back and forth while pulling up on it. It will come out. Hit harder, you wont hurt it :) Then turn it and smack it back in. You can clean it off and put some green loctite on it if you want but I have never found it necessary. I pulled one out of an Oldsmobile manifold yesterday so I could shot blast the intake.
· Super Moderator
This is what it looks like removed. May help with removal. Bill K et al have given you a method.
Cylinder Drinkware Nickel Rim Gas
· Super Moderator
And is it done?
1 - 16 of 16 Posts
