1 - 2 of 2 Posts
My '71 factory air car has the vacuum hot water valve mounted on the passenger side front of the intake (where it moved from the fender in the '70 model). I have seen several other cars with the same setup. However I just recentley saw photos of a supposed unmolested original SS454 A/C car that did not have a water valve at all (?????). Was it thown away some time in it's lifetime or do not all A/C cars have this setup?
71s got the water valve 72s didn't. I can't say that holds true in all cases. On cars that came with the water valve the firewall grommet for the A/C vacuum line(s) will have two lines, no water valve-one line.
1 - 2 of 2 Posts
