Hey guys -
I just replaced my leaking stock replacement radiator and went with a Be Cool set-up. I also converted from a clutch fan to an electric. In order to get a little more room, I removed the spacer between the radiator and the core support.
Between the radiator now being three inches further away from the water pump and the thermostat housing, the Be Cool radiator has the tanks on the sides rather than top and bottom. Because of that, the hoses are also further apart. Has anybody done this swap before? If so, can you give me an idea what hoses you are running? Clearly the stockers won't work anymore. Thanks guys!
Andy
Andy
