I fail to see how they can call this one a masterpiece:
I'd say those are minimum 315s in the back, if not 335s. But when you can fit that size tire with a mini tub under Chevelle, moving the wheels outward 4-5 inches just makes it look weird.Tires are too narrow to pull off a wide-body look.
I have tires wider than that under my stock fender openings.
315s fit a 68-72 rear without even a mini-tub. I had 315s on my '69 with just trimmed lips, and the 70-72 bodies have even more room than 68-69. The fronts look 275-285 ish, which you can also fit under stock fenders while running stock inner fenders and a low stance.I'd say those are minimum 315s in the back, if not 335s. But when you can fit that size tire with a mini tub under Chevelle, moving the wheels outward 4-5 inches just makes it look weird.
Kinda what I was thinking. Will say ive seen a lot worse offerings of an ultimate Chevelle.Knock the windows out of it and put a number on the door and it will look like a 70's roundy round car.
