You are correct about the assy manual, the two forward bolts that tie that hood latch reciever to the header panel are the ones, the horns are on top with the latch reciever being sandwhiched in between. The spade connectors face upward. You probably already have this part but i'm bored and going to type it anyway.....The wiring for the horns starts as a a single black wire that goes thru a hole in core support beside the horn relay, across to the inside of the header panel and finally splits into two female spade connectors to the horns.
Paul
Thanks. That's what I neede to know. I mounted them there, but my harness wire seems too short for the horn on the dirvers side. ok for the other. I might not have the right horns or brackets. Will have to try to get different brackets, or splice a section in the harness.
