Hey guys. I'm getting far enough along in the development of the Hooker 64-67 A-body LS swap system components to be able to begin share more technical information, as well as CAD images and photographs of the products that will be coming.
Two sets of engine brackets and the transmission crossmember have been designed and installed on a 67 Chevelle and a 65 GTO to validate their fitment geometry as the first step in the process.
The engine brackets are designed to be used with 4th-gen F-body engine mounts (rubber or aftermarket poly) and bolt to the stock holes in the frame with no drilling required.
The crossmember will include mounting angle brackets for each frame rail that neutralize the crossmember mounting frame differences between the 64-66 and 67 frames and fit all the non-boxed A-body frames. They also pull double-duty as frame stiffeners as an extra bonus. You will be able to install a T56/T56 Magnum, 4L80/4L85, 4L60-4L70, TH400 or 2004R behind an LS in your car using this crossmember and either of the Hooker engine mounting bracket sets.
I will be starting on the design work of the headers (mid-length and long-tubes) and exhaust systems (2.5" and 3") next week, which will take me through the end of the month to complete.
