1 - 2 of 2 Posts
I think one wire (pink or red) goes to the "ignition fused" terminal on the fuse box. The gray wire will go to a instrument light fused terminal, the brown wire will go to the coil ("-" side).
For the 67, there should be a wire (dark green?) for the blinker? Or is it just a socket... I don't know (I never had a 67)... There might also be a black wire to chassis ground...
Of course, aftermarket tach might have different color wiring...
A factory assembly manual (about $20) should show the size and location of any holes needed for mounting, etc...
1 - 2 of 2 Posts
