1 - 2 of 2 Posts
I never posted the issue I was having on here but thought my results might be interesting to a few others.
I have a 780dp from Pro Systems that I ordered when I built my 406sb a few years back. This carb has performed flawlessly until now. I changed heads from Eddy e-techs to AFR's eliminators last year and the carb was still great. This winter I went to 1 3/4 headers with 3" pipe to a X and then the original 2 1/2 back from there. My old system was 1 5/8 headers to a H pipe , all 2 1/2" pipe. I also just completed a swap over to a m22 from a th350.
Anyway, last week I checked my timing and tried to adjust the idle/mix screws. Turning the screws in increased my idle rpm substantially and cleaned the idle up a bit. The problem was I couldn't lower the idle rpm with the idle screws. Both the primary and secondary were backed right out and still wouldn't lower the rpm enough. Richen up the mix screws and the idle would back down.
The pro-systems carb comes with the throttle blades drilled, both primary and secondary. I phone Patrick and asked if plugging the holes in the blades might help. He said it might but gave me a few other things to check first.
I tried his suggestions Saturday but nothing helped. I JBed the holes closed and let it dry until Sunday. I put the carb back together and bolted it on. I now have complete control again. I found this quite interesting that it worked. My initial reasoning for closing the holes in the butterflies was that maybe with the bigger exhaust it was breathing better and pulling too much fuel at an idle. I don't know, all I know is it worked.
Jerry sounds like you went lean onthe idle withthe freer exhaust .I'm surprised Patrick did not tell you to change the idle air bleeds rather than close up the holes ........to get it to idle do you have to adjust throttle blades well into the transistion slot ? Your cam not that big so you pbly never needed holes in throttle blades to begin with ...............................idle airbleeds should have cured your problem but sounds like you accomplished same thing with plugging the blades
......I'm just going thru a retune with my Pro Systems carb after cam change ......my 950 only has the sec drilled not the primaries ...... I had to open up the idle mix screws real rich to get it to idle properly and sec throttle had to be open .the prim throttle blades are just about closed very little transistion slot exposed 'square" ...... but Iam going to try different airbleed and get the sec blade closed my wide band has it about 16-1 at idle right now
1 - 2 of 2 Posts
