1969 Chevelle SS 454
I have a Holley 4150 carb on a 454 with a 700R4 attached. I was wondering if anyone could supply a picture of their throttle linkage setup (particularly if you are running a 700R4). I know I will need a lever (p/n 20-121) for the transmission setup, but would be great to see the entire setup with the return springs and everything.
Thanks for your help.
John
Thank Robert. That really helps. What is the spring attached to on the other end (outside of the picture)?
I was considering drilling a hole in the bracket you show and have the springs face the other direction (attached on the lower portion of the throttle lever.) I think I have seen this setup in the past, but can't recall exactly what they did.
John
The picture in a reply near the top is pretty much exactly as I ended up doing. I am not familiar with the part numbers you posted. Can you identify the part from the picture?
John
